1999 Ford Expedition
170,000 MILES • V8 • 2WD • AUTOMATIC
JUANANUNO
what is code po401
Oct 24, 2008 at 7:01 PM
MASTERTECHTIM
  • 4,750 POSTS
its egr low flow. this is caused by the egr pressure sensor 99 percent of the time. the part has been updated to plastic from aluminum which were corroding. replace this sensor and im sure your problem will go away. there are 2 rubber hoses from the exhasut that connect to it and i wire connector. very inexpensive repair, about 40-60 dollars. hope this helps
Oct 24, 2008 at 10:37 PM
