1998 Ford Expedition turn signal
GREG ANDRIUNAS
Electrical problem
1998 Ford Expedition 6 cyl Four Wheel Drive Automatic
rear driver's side turn signal bulb needs to be replaced. where is the bulb case and how do i open it?
May 17, 2009 at 6:34 AM
  • 110,248 POSTS
WHen you open the rear hatch, look where the lens assembly meets the body. THere are two screws there that need to be removed. Remove the screws and the lens will come out and then you will have access to the bulbs.
If you have other questions, let me know.
Jun 19, 2009 at 12:39 PM
