What are the signs when an oil pressure sensor goes bad?
Jan 30, 2009 at 4:22 PM
✓Experienced Mechanic
Oil light is usually a good indicator... The oil sender is located on the oil filter adapter on your 4wd truck. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.................
