installed #2 cyl. coil and started engine and got 1131 and 1151 codes. whats the fix
Aug 20, 2010 at 6:30 AM
MERLIN2021
✓Experienced Mechanic
It can mean you need new O2 sensors, both front sensors are stuck on lean, and not switching as they should, or you have a major vacuum leak. Air duct back in place? Also possible the fuel pump is on the way out.
