1998 Ford Expedition not cooling effeciently
PKAELIN
  • 1998 FORD EXPEDITION
Air Conditioning problem
1998 Ford Expedition V8 Four Wheel Drive Automatic 215xxx miles
my air conditioner shows maximum pressure on a after market gauge. The lowest temputure registered on a thermometer is 70 degrees. During the heat of the day the thermostat does not go below 80 degrees. There doesn't appear to be a leak since everything is constant. I have clean the condensor core with air and water. Hasn't made any difference.
any suggestion on what to do to increase the effectiveness of the air conditioner?
Sunday, July 11th, 2010 AT 4:52 PM
  • 109,885 POSTS
Are you sure the blend door is working properly?
Sunday, July 11th, 2010 AT 11:19 PM
PKAELIN
Yes the blend door is closed.
Thursday, July 15th, 2010 AT 8:48 PM
