1998 Ford Expedition linkage?
150 MILES • V8 • 4WD • AUTOMATIC
FEREBEE64
1998 Ford Expedition - automatic transmission - problem just happened - park is now reverse - reverse is now neutral - and so on - no signs of transmission problems before - fluid is good - no un normal shifting problems - I think its a linkage problem - i cant get it in to the shop for a few days (up to 5) i need it to go to work - is there any danger of operating it this way until i can get it fixed? it seems to run fine - just the gears indicator on the steering wheel is "shifted" one position - thank you for help.
Sep 16, 2010 at 7:19 AM
  • 110,251 POSTS
It isn't a trans problem, so things will be fine. Just make sure you have it in the correct gear.
Oct 4, 2010 at 4:35 AM
