1998 Ford Expedition know
SERGIO4317
Electrical problem
1998 Ford Expedition V8 Two Wheel Drive Automatic
i have a problem on p0133 code
but i change a sensor h20s upstream sensor before at cataly .but the problem still there. so do you have any idea on that problem. because the truck when is cold run fine but after 10 or 15 min loose power
or after 35 mph i dont if need to change other sensor
Mar 3, 2009 at 11:44 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:c2925220bb="sergio4317"]Electrical problem
or after 35 mph i dont if need to change other sensor[/quote:c2925220bb]
Here is the code def...
P0133 Oxygen Sensor Circuit Slow Response (Bank 1 Sensor 1)
Bank 1 is the passenger side
Bank 1 Sensor 1 is the sensor in the exhaust Manifold.
Bank 1 Sensor 2 would be the one you changed.
Mar 3, 2009 at 12:58 PM
