1998 Ford Expedition is it a miss??
175,000 MILES • V8 • 4WD • AUTOMATIC
ZBUCK_1
when the rpms get to around 1300-1600, the engines feels like it has a terrible miss. below that range or above it...it is not that bad at all, sometimes not even noticeable. I have changed plugs and even a couple of coil packs that looked like they might be bad, but it hasn't helped at all.
Feb 22, 2010 at 2:52 PM
  • 75,988 POSTS
Hi zbuck_1@yahoo.com, Welcome to 2carpros and TY for the donation
Your probable causes-Inspect and test all the following listed below:
Oxygen sensors.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Fouled/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 22, 2010 at 3:35 PM
ZBUCK_1
Kinda generic answer isn't it? Not much help.... :(
Feb 23, 2010 at 2:20 AM
  • 75,988 POSTS
One of this components will cause your problem I suggest you check it top to bottom and get back with some testing results so that we can continue, remember were not there with the vehicle your my eyes here-Misfires can be hard to deal with-could be compression/fuel or spark problem
Feb 23, 2010 at 5:23 AM
