1998 Ford Expedition Gauges
98,000 MILES • V8 • 2WD • AUTOMATIC
EARL09
None of the gauges are working. Is this likely to be a fuse, or what are some other possible causes?
Feb 3, 2009 at 2:07 AM
  • 110,248 POSTS
Hi:
Did this all happen at once? Also, you can check the fuses, but I doubt that is the problem. Look for broken body grounds under the dask, make sure the wiring to the dash hasn't come unpluged. If everything looks ok, you may want to have the body control module (BCM) tested.
Feb 3, 2009 at 11:23 AM
