my four wheel light indicator won't come on. Does that mean it doesn't work??
Nov 8, 2008 at 1:42 AM
✓Experienced Mechanic
Hi: It could be a bulb. However, it may not be in 4 wheel drive. En easy way to check is to simply drive on loose gravel, stop and see if the tires spin when you're in 4 wheel drive. If they don't, it's working. If it spins, you're not and will need to have the actuator checked.
