1998 Ford Expedition engine missing
150,000 MILES • V12 • 4WD • AUTOMATIC
METALCUP
Truck starts fine, idles great, has a 5.4 fuel injection trition, upon putting in drive and taking off, the motor starts to chug, miss, and will come out of it upon acceleration, or putting it in netrual , and when in netrual reving it up does not miss, and put it back in drive it misses, sputters, somedays it doesnt miss, i coded it, it said it was vaccuum problem, i did find some vac problems, fixed them, but it the same problem, im wandering if the fuel filter, or fuel regulator, or even fuel pump is bad, money tight and dont want to do the part replacement deal to find out problem, thank you for your time
Oct 2, 2010 at 6:27 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Oct 3, 2010 at 12:23 AM
