1998 Ford Expedition change fuel filter
120,050 MILES • V8 • 4WD • AUTOMATIC
AADELL867
how do i change the fuel filter?
Aug 12, 2008 at 10:12 AM
MERLIN2021
  • 17,250 POSTS
On each end of the filter, there is a U shaped clip, relieve the system pressure, then use a fingertip to spread the clip at the bottom, and pull it out, then pull the line off.
Aug 12, 2008 at 10:22 AM
KJEHLE
You can purchase a special tool that will slide over the in-line filter and push into the locking connector. They are inexpesive and can be found at any uto part store.I use them every time I change the filter and it works pretty well.
Aug 15, 2008 at 3:30 AM
