Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Expedition
Electrical
Battery
Replace/Remove
1998 Ford Expedition battery replacement
1998 FORD EXPEDITION
98,000 MILES • V8 • 2WD • AUTOMATIC
CRAIG LYNEIS
MEMBER
1 POST
How many cold cranking amps do I need When I am replacing my battery? Want to purchase proper battery
Jan 19, 2009 at 5:03 AM
OBXAUTOMEDIC
Experienced Mechanic
[quote:5eb801f554="craig lyneis"]Electrical problem
1998 Ford Expedition V8 Two Wheel Drive Automatic 98000 miles
How many cold cranking amps do I need When I am replacing my battery? Want to purchase proper battery[/quote:5eb801f554]
Hello Craig,
You will need at least 650 CCA, I would recommend 850 CCA. You should be able to look it up yourself if your go to walmart or k-mart.
Jan 19, 2009 at 5:13 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
