1998 Ford Expedition air conditiontioning compressor/ bypas
2,231 MILES • V8 • 2WD • AUTOMATIC
RLO562
when installing a bypass pulley instead of replacing the whole air conditioning compressor unit how exactly do you do it???? do i have to completely remove the a/c compressor thing or just remove the pulley from the air conditioning compressor. also how can i see a diagram of the a/c compressor components so that i can visually comprehend whats go on there??
Nov 6, 2008 at 5:18 AM
2CARPRO JACK
  • 11,533 POSTS
By pass pulleys are usually desingned to go in place of the compressor, so you will most likely have to remove it.I have included the only pic I could find of the front of the a/c compressor, hope this helps
https://images.2carpros.com/forum/automotive_pictures/1639_ford_ac_1.jpg
Nov 6, 2008 at 11:59 PM
