1998 Ford Expedition #4 cylinder coil
ENG961
  • 16 POSTS
Engine Performance problem
1998 Ford Expedition V8 Two Wheel Drive Automatic
I have a bad coil on the #4 cylinder, what harm to the engin would I do if I drove the car about fifty miles?
Jan 21, 2010 at 10:01 AM
  • 110,248 POSTS
Actually, it SHOULDN'T hurt too much other than bad fuel mileage, lack of power, and a miss. Hoever, remember the fuel will not get burned in that cylender that can make its way to the catylatic converter and into the oil thinning it. If you can avoid it, I would, but you should be okay. Please understand I can't guarantee it.
Let me know if you have other questions. Also, they are easy to replace. I would recommend replacing it. If you need directions, let me know.
Jan 21, 2010 at 12:24 PM
ENG961
  • 16 POSTS
I need instruction as to how to install it
Jan 22, 2010 at 2:02 AM
  • 110,248 POSTS
This is basic. Just unbolt the coil pack, disconnect the wiring harness remove the old coil and reverse the order to replace it.
Jan 24, 2010 at 11:57 PM
