1997 Ford Expedition rough idle
182,000 MILES • V8 • 4WD • AUTOMATIC
PMEDIC666
when i start my vehicle it is rough idling , it stutters when you accelerate but as soon as you get to abou 15mph it starts to smooth out and runs better, I have changed the coil packs , plugs, wires,fuel pump, fuel filter, and there is a mis fire on #3..can you help?
Nov 16, 2008 at 3:07 PM
  • 75,988 POSTS
*If it applies -check compression and * injector for that cylinder
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel
Might also want to check the idle air control valve/motor and throttle position sensor-
Nov 16, 2008 at 6:59 PM
