*If it applies -check compression and * injector for that cylinder
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel
Might also want to check the idle air control valve/motor and throttle position sensor-
SPONSORED LINKS
Monday, November 17th, 2008 AT 2:59 AM
