1997 Ford Expedition rear brake line
1997 FORD EXPEDITION
122,222 MILES • V8 • 4WD • AUTOMATIC
POG692000
how do i replace the drivers side rear brake line
Sep 27, 2008 at 2:12 AM
BLACKOP555
  • 10,386 POSTS
remove the old fittings at the nearest connector where you can remove them with a FLARE NUT WRENCh.
next step is bend the new one to the right shape then reattach, bleed lines, abs and your good to go
a tip, press brake pedal down a little over half way to prevent loosing fluid.
Sep 27, 2008 at 3:12 AM
