1997 Ford Expedition Pitarm to be replaced by Ford dealer
NOTSODUMBBLONDE
Suspension problem
1997 Ford Expedition V8 Four Wheel Drive Automatic
Went in for a recall by ford.... ask the mechanic to also check the very back squeeking in the front suspension. They said the pitarm needs to be replaced and I afraid I am being ripped off. They say the labor hours are 4.5 at $105.00 an hour. I have checked with two mechanic shops and they said it should only take 1.6 hours. The dealer is including in those hours an alighnment which they claim to take 2 hours. So pitman arm replacement and alighnment 4.5 hours. ????
Feb 3, 2009 at 1:52 PM
  • 110,246 POSTS
Hi:
I looked up the labor on the pitman arm. It shows 2.4 hours. It shouldn't take 2 hours for an alignment. I strongly recommend getting a second opinion from a tire shop for the alignment (at least). The factory price for the pitman arm is $108.33.
I don't know where you live, but wow! I can't believe the labor rate. Here (near Pittsburgh) 60 an hour is about average.
If you have other questions, let me know. Also, replacing the pitman arm does not justify an alignment.
Feb 4, 2009 at 8:21 AM
BEN-2CARSPROS
  • 7 POSTS
i replaced my own and had ailgment done for $49.
get someone to do it for you or do it yourself.
Feb 9, 2009 at 4:29 AM
