1997 Ford Expedition no heat
RMC3711
  • 1997 FORD EXPEDITION
Heater problem
1997 Ford Expedition V8 Four Wheel Drive Automatic
I am not getting any heat from my car, it runs AC
Saturday, December 12th, 2009 AT 2:28 PM
  • 109,885 POSTS
I need to know a few things. First, is the engine running at normal temp? If so, with the engine running, hot, and the heater on high, feel both heater core hoses. They should be hot. If one is and one isn't, chances are the core is plugged. If both are hot, then there is an item called the blend door. Its position determines whether you get heat or AC in the car. It could be stuck or not working and only allowing the AC to go through.
Let me know what you find.
Saturday, December 19th, 2009 AT 11:46 PM
