1997 Ford Expedition Interior Lights wont go out
1997 FORD EXPEDITION
140,000 MILES • V8 • 2WD • AUTOMATIC
NECAPPS
  • 7 POSTS
1997 Ford Expedition. Exterior and interior lights remain on for 10-15 minutes after parking and closing all doors. Switches are not visable in door jams, must be internal. I'm sure there is a relay associated with the system. How do I troubleshoot? Thanks Nathan
Dec 14, 2008 at 11:03 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Sounds like door ajar switch is sticking. It is located inside of door panel. Prior to removeng door panel try spraying latch assembly liberally with WD-40 or similar product - operate door a few times and then spray with silicone. This procedure may save you some labor. Common problem with these vehicles
Dec 14, 2008 at 11:10 AM
