1997 Ford Expedition Horn
130,000 MILES • V8 • 2WD • AUTOMATIC
HYTOP0
My horn won't blow from the steering wheel, When the panic button is pressed it will blow. How can I get into the steering column to repair
Mar 19, 2010 at 8:04 AM
  • 110,246 POSTS
You need to remove the steering wheel to access the the steering column. However, if you don't have experience with an airbag, you may want to have an experienced tech do the work.
Mar 22, 2010 at 6:08 AM
