1997 Ford Expedition brakes get really hard once in a while
1997 FORD EXPEDITION
106,000 MILES • V8 • 2WD • AUTOMATIC
FICASTELLL
My brakes become really hard just once in a while and I need to release some pressure and push it again in order to brake, fluid is normal, pedal pressure is normal too.
When the brakes get hard I can feel a vibration in the pedal and there is a fluid stain in the cruise control deactivation switch, wich I believe is broken because my cruise control doesn´t work.
Jun 11, 2009 at 5:49 AM
  • 110,244 POSTS
First, there was a recall on the wiring to the cruse control. If you haven't had the wiring replaced, do so. Vehicles where catching fire from faulty wiring to the switch on the master cylender. Second, if the brake pedal gets hard to push, have the brake booster tested to make sure there isn't a vacuum leak causing it not to function.
Jun 18, 2009 at 5:10 PM
