1971 Ford Expedition battery
18,000 MILES • V8 • 4WD • AUTOMATIC
MARLA PEELMAN
I need to know how to find problem envolving battery. Their must be some electrical issue touching wires? i do know the cables are spliced together is this an ok way to wire battery cable to make it longer? I am guessing no. what troobleshoting tactics should I attempt. "I am a woman" if you didn't figure me out yet. I try to do as much for my ride as possible.
thank you,
marla jean
Mar 13, 2010 at 7:04 PM
  • 110,248 POSTS
Marla Jean:
The cable from the battery shouldn't be spliced together unless you mean you replaced the battery terminal that connects to the post. They make a replacement that in a manner of speaking splices the old wire to a new connector.
Is that what you mean? Also, can you explaine how you spliced them?
Mar 22, 2010 at 6:33 AM
