2004 Ford Excursion Speedometer stuck
98,500 MILES • V8 • 4WD • AUTOMATIC
BIG FAT TUNA
My speedometer recently started getting stuck at approximately 30mph, regardless of actual speed. If stuck when the ignition is turned off, it cycles back to zero but when the ignition is turned back on, the needle returns to where it was when the vehicle was shut off.
Not sure where to begin the troubleshooting process. Your guidance is appreciated. Thank you.
2004 Excursion Diesel 6.0 Eddie Bauer 4wd
Nov 3, 2008 at 10:57 AM
JAMES W.
  • 2,394 POSTS
If you hook the vehicle up to a scan unit and run it down the road it will tell you what the computer thinks the actual speed is. If the scan unit says you a doing 30 mph and you know you're going 55 mph then the speed sensor is bad. If scanner says you're doing 55 mph and the speedo says 30 mph, the speedo head is bad.
Nov 3, 2008 at 3:59 PM
