2003 Ford Excursion Telescopic mirror with signal light.
TMUNDAY
Electrical problem
2003 Ford Excursion V8 Four Wheel Drive Automatic
Will the telescopic mirrors with signal light work on my 2003 ford excursion. It does have power mirrors, but no signals. It is an Eddie Byuer. Thanks
Jun 30, 2010 at 11:30 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The telescoping side mirrors will mount on if you got it for the correct model ,year . Does your original side mirror have a signal light? If not then you may have to run the wiring yourself for the signals and tie it into the turn signal switch wiring on the steering column. If it is the power telescoping mirror then it would not work, because your power mirror switch does not have a switch to operate that adjustment. You could go with the manual telescopic mirror with signal light though..
Jun 30, 2010 at 1:26 PM
