2003 Ford Excursion door
JDCARRILLO
2003 Ford Excursion V8 Two Wheel Drive 10200 miles
my door light on my console is on and my lights also i have checked all doors and they are closed can not find nothing jamed in between the doors
Dec 1, 2009 at 2:11 PM
BLUELIGHTNIN6
  • 16,542 POSTS
faulty or sticky door jamb switch will cause this to happen. try lubricating all door latches , including rear, with WD40 to see if it will loosen up the switch. if not then you will have to test each switch to find which is bad.
Jan 11, 2010 at 9:47 AM
