2003 Ford Excursion Acceleration and Sputtering
90,441 MILES • V8 • 2WD • AUTOMATIC
NARA0606
My excursion starts sputtering and shaking when accelerating, especially when I go between 40-55 miles per hour.
what could be the problem?
nara
Apr 29, 2009 at 1:21 AM
  • 110,248 POSTS
Has the check engine light come on? Also, have you had the fuel pressure tested?
Jun 20, 2009 at 3:02 PM
CASHWORTH
One (or more) of your Coil Over Plugs, is bad. Very common on the EX's. Their about $90 a piece. you'll want to take it to a shop though, they have the tooling to test which one it is. Tell them to look at the COP's as it's a common problem. Has happened to me three times. I've replaced 5 already on my V-10.
Mar 20, 2010 at 11:01 AM
  • 110,248 POSTS
Cashworth can be right. THat is why I asked about the check engine light. A misfire should set the engine light on your engine and identify which one cylender is having the problems.
Mar 20, 2010 at 5:48 PM
