2002 Ford Excursion turn signals
101,000 MILES • V8 • 4WD • AUTOMATIC
JFAVIS
trun signals not working, have replaced all the bulbs. can not locate fuse or relay
Nov 13, 2009 at 5:15 AM
JDL
  • 16,098 POSTS
Welcome to the forum, check fuse 27, 15 amp in central junction box. Not only check fuse, use a testlite on the fuse circuit, it should go hot when you turn on the key. That circuit is voltage for the turn signal.
Nov 13, 2009 at 8:02 AM
