2002 Ford Excursion Putting car into gear
WSBILLINGS
Engine Mechanical problem
2002 Ford Excursion Four Wheel Drive Automatic
The car started just fine but it will not go into gear. The only other issue we have is the break fluid is leaking. I can use any advise. Thank you
Oct 8, 2010 at 10:02 AM
  • 110,251 POSTS
Where is the leak? Also, are the brake lights coming on?
Oct 12, 2010 at 3:44 AM
WSBILLINGS
No brake light and the leak, I don't know where it is coming from.
Oct 12, 2010 at 9:49 AM
  • 110,251 POSTS
The brake light switch provides power to the park lock actuator so you can shift from park. chances are the switch is bad. It is located under the dash at the top of pedal.
As for the leak, do you see any wet spots under the vehicle? Also, check behind the wheels to see if there is anything wet as well as under the hood.
Oct 13, 2010 at 12:22 AM
