2002 Ford Excursion P0722 engine code engine shuts off
MYPSYCHO5OH
Engine Performance problem
2002 Ford Excursion Four Wheel Drive Automatic 128000 miles
I have the output speed sensor check engine code on my excursion. I read that it could possibly be a grouund issue instead of the sensor. I am going to replace the sensor but if the problem persists where are all the main grounds located on the block. That way if it is the problem i can look there next.
Jan 14, 2010 at 8:15 AM
  • 110,248 POSTS
If you follow the ground wire from the battery, it will lead you to the only grond on the engine,
May 6, 2010 at 4:20 AM
