2002 Ford Excursion 7.3 Banks turbo Diesel dying on cold st
2002 FORD EXCURSION
58,000 MILES • V8 • 4WD • AUTOMATIC
REEDRANDOY
My 7.3 Banks turbo Diesel is dying on cold starts. Sarts up fine, but if I don't let it warm up into the temp gauge (10-15 min) it will bog out ad die when shifting into second. Then it' difficult to restart. Changed fuel and air filters....?? Ve noticed less power now too, even once it's warmed up.
Oct 21, 2010 at 7:13 AM
TECH1FORD
  • 102 POSTS
so when it is warm is if fine or is it a loss of power all the time, but it will not die out when warm
Oct 25, 2010 at 1:06 PM
REEDRANDOY
Yes, when it's warm, it won't die, but I have noticed a little loss of power, too. Cold though, it dies right away if I try to drive it. I was told it may be a fuel pump mounted under the rig??
Thanks!
Oct 25, 2010 at 1:55 PM
TECH1FORD
  • 102 POSTS
does your check engine light come on, when you try to give it fuel or when it dies just it just die or does it start running rough then die.
Oct 26, 2010 at 3:21 AM
