2001 Ford Excursion Starter engaging while driving
153,000 MILES • V8 • 2WD • AUTOMATIC
JSANDERS0213
Just recently the starter engages again on its own about 20-30 seconds after you start the excursion. I have replaced the solonoid on the fender, the starter and the ignition switch. I have wired another switch in to kill the power to the starter after i start the vehicle so i do not ruin the fly wheel. Two brand new batteries. The battery light stays on and flickers. The truck died last night because the truck is running on batteries. Tested the alternator and it passed all tests at the shop. What is left?
Nov 16, 2009 at 5:01 AM
  • 75,988 POSTS
Check the starter relay could be sticking if not check the ignition switch again
Nov 16, 2009 at 5:08 PM
