2001 Ford Excursion power window pass. side front
153,000 MILES • V8 • 4WD • AUTOMATIC
DSTAIB
window will power down but not up. took button from back and still the same.dims the light when bottoms out driver side does nothing
May 19, 2009 at 2:09 PM
RACEFAN966
  • 5,029 POSTS
OK from the wiring diagram it is either the master switch on the drivers door or the window motor. Now you can check to see if the window motor is getting power at the white wire with the black stripe as this is the wire that gets power in the up position. Let me know what you fnd.
May 19, 2009 at 3:02 PM
