2001 Ford Excursion ignition coil
JY580IW
Engine Performance problem
2001 Ford Excursion Four Wheel Drive Automatic 120000 miles
Have engine code p0356need to know if this is #6 coil
Aug 29, 2010 at 4:58 AM
  • 110,248 POSTS
That is the number 6 cylender. It could be a bad coil, wiring issue or a pcm problem. I would first suspect the coil pack.
Oct 12, 2010 at 3:50 AM
