2000 Ford Excursion Wont Crank
GIRLSILLY
  • 2000 FORD EXCURSION
  • V12
  • 4WD
  • 180,000 MILES
All of the sudden my excursion will not start. It will not crank, spin, or click. I suspect electrical. I have taken the starter to the local car parts supply to have it tested and it is fine. Replaced the battery with a deep cell 12v battery. Still nothing. I can jump start the starter and it will run with no problems (except that I cannot restart it with the key). Not sure what to do next.
Thursday, November 4th, 2010 AT 7:35 PM
  • 109,872 POSTS
Have you checked the ground to the engine block?
Friday, November 5th, 2010 AT 10:46 AM
GIRLSILLY
Yes, my excurs has an anti-theft system and I am thinking that may be the problem or a relay. Am I far off?
Friday, November 12th, 2010 AT 4:45 AM
