2000 Ford Excursion VIBRATION
153,000 MILES • V12 • 4WD • AUTOMATIC
SORGDRAGER5
MY EXCURSION VIBRATES WHEN AT AROUNG 65-70 MPH AND WHEN LIFTED THE TIRE IS ABLE TO BE WIGGLED. IS THIS A BALL JOINT PROBLEM?
Feb 15, 2009 at 7:58 AM
  • 110,251 POSTS
IT could be a tie rod, ball joint, wheel bearing... When you are shaking it, have a helper watch to see where the play is coming from. NOTE: A tie rod will give you left and right play. Ball joints will be up and down, and a wheel bearing will move in any direction.
Let me know what you find or if you have any questions.
Jun 20, 2009 at 3:26 PM
