2000 Ford Excursion turn signals, emergency flasher and bre
110,000 MILES • V8 • 2WD • AUTOMATIC
JSAUCEDO9
I got a 2000 Ford Excursion, the turn signals, emergency flashers and break (stop) lights don't work. Regulars lights do work front and back as well as the top break (stop) light. I checked all fuses and bulbs and they're in working conditions, none burnt out. What can be wrong?
Jan 23, 2010 at 12:14 PM
  • 110,248 POSTS
Using a test light, check the socket with a test light to see if there is power to them. Also, under the driver's side on the rear part of the frame, there is a plug. Make sure it is clean, tight, and not corroded.
Let me know what you find.
Mar 1, 2010 at 12:25 AM
CASHWORTH
You need a multifuntion switch. It's the directional lever assembly. It conrols all the lighting, and is a frequent problem on every Ford. It's about $70 at any part store or your dealer.
Mar 20, 2010 at 10:51 AM
