2000 Ford Excursion transfer case
HATEFORDS
Transmission problem
2000 Ford Excursion Four Wheel Drive Automatic 276000 miles
after replacing the complete t-case the vehicle will not engage to low range as before the swap of t-cases it will go into 4-high but not 4-low, everything is new even the shift motor on the t-case. i'm lost please help
Nov 12, 2008 at 8:46 AM
  • 110,251 POSTS
Are you getting power to the actuator when you switch to 4 low?
Jun 20, 2009 at 3:43 PM
