2000 Ford Excursion No 4 Wheel Drive
195,000 MILES • V8 • 4WD • AUTOMATIC
JOHN1DUP
Front wheels do not engage, there is no vacuum to the hubs or differental, vacuum pump working (have control Fuse postion 6 (15amp) is good. I don't have an electricial diagram to know where the circuit goes after the fuse (a relay or soloenoid).
Can you help!
Aug 17, 2010 at 11:01 AM
  • 110,248 POSTS
Here is a schematic, but it may be too small to read. I hope you can enlarge it.
https://images.2carpros.com/forum/automotive_pictures/249084_5_50.jpg
Have you checked to see if there is power to the actuator on the transfer case?
Aug 17, 2010 at 5:42 PM
