2000 Ford Excursion I THINK NO FUEL TO ENGINE
A8MACS
Engine Mechanical problem
2000 Ford Excursion Two Wheel Drive Automatic 50,000 miles
Never had a problem with the excursion. vehicle might sit alot. ran it the other day around the block to warm up. 15 min later wouldn't start. It would turn over and over, but it wouldn't start. someone said something about a relay or fuse. if not fuse what else. thanks
Apr 20, 2010 at 11:25 AM
  • 110,246 POSTS
Is the check engine light on? Have you checked fuel pressure>
May 6, 2010 at 3:42 AM
