2000 Ford Excursion Fuel Pump
2000 FORD EXCURSION
149,000 MILES • V8 • 4WD • AUTOMATIC
NANWILSON74
Hello there. We own a 2000 Ford Excursion V10(not an option above) that keeps burning through fuel pumps. We have owned for a little over 2 years and we are about to install the 5th fuel pump. It just has to be something else making the fuel pumps go out, and can't be the fuel pump itself. Any ideas?? Thank you so much
Nov 24, 2009 at 5:26 AM
  • 110,240 POSTS
Are you using factory fuel pumps or aftermarket (remanufactured) pumps?
Dec 2, 2009 at 9:04 AM
NANWILSON74
Remanufactured. We are going to put in the $400 Ford factory fuel pump this time and see if that will do it. Is this what you would suggest? Thank you so so so much for replying..........Leanna
Dec 21, 2009 at 11:22 AM
