2000 Ford Excursion Fuel Filter
2000 FORD EXCURSION
150,000 MILES • V12 • 4WD • AUTOMATIC
EASYND1
How do you remove and replace the fuel filter?
Aug 6, 2009 at 12:55 AM
  • 110,240 POSTS
The fuel system remains under pressure, even after the engine has been turned OFF. The fuel system pressure must be relieved before disconnecting any fuel lines. Failure to do so may result in fire and/or personal injury. Always disconnect the battery prior to work.
The filter is located under vehicle, driver side, below seating area, front of fuel tank, mounted on frame rail in fuel line. Basically you just unbolt the fuel inlet and outlet lines from the fuel line and remove the filter. It's an easy job.
Oct 26, 2009 at 3:14 AM
