2000 Ford Excursion Cuts off when gas pedal pressed
DRJONES
Engine Performance problem
2000 Ford Excursion Two Wheel Drive Automatic 200000 miles
2000 Ford Excursion v10 engine
we have replaced the fuel pump and the fuel filter
The truck cuts off when I press the gas pedal.
Apr 30, 2008 at 12:50 PM
FLEXY5
  • 512 POSTS
Does it spit and sputter, then gradually die, or does it simply cut out all at once? A few things to check either way: mass air flow sensor, throttle position sensor, and crankshaft sensor. If ou could post back with the response to the question, we can go a little deeper if needed.
Apr 30, 2008 at 2:25 PM
DRJONES
It cuts off all at once
Apr 30, 2008 at 11:55 PM
FLEXY5
  • 512 POSTS
You may want to check the Throttle position sensor first. Since it happens when the throttle is touched, it may be shorting out.
May 11, 2008 at 11:51 AM
