2000 Ford Excursion can't find cause of fuse shorting out
2000 FORD EXCURSION
207,000 MILES • V8 • 4WD • AUTOMATIC
DAISYJ
The trip computer turn signals and seat heater keep shorting out 15a fuse. Have checked heaters, wipers and
lights and can't find the cause. Runs for about 4 hours with new fuse, then shorts out.
Jan 25, 2010 at 7:26 AM
  • 110,240 POSTS
Try disconnecting the plug for the heated seat. Chances are something has shorted there. You can do it at the switch or I believe you have access to the wiring under the seats.
Let me know if that changes things, and thanks for using 2carpros.com.
Jan 25, 2010 at 1:56 PM
DAISYJ
We have unplugged seat heater, put a new switch in directional signal and high beam arm, taken down steering column and removed seats to check wiring there, but still blowing out fuses. What else do you suggest? Thanks again
Feb 1, 2010 at 12:40 AM
  • 110,240 POSTS
I'm glad to help. This is going to be a tough one. Is the trip odometer that you mentioned on the overhead consule or the one with the speedometer?
Feb 1, 2010 at 11:38 AM
DAISYJ
The trip computer is on the overhead console. Thanks again.
Feb 1, 2010 at 12:39 PM
  • 110,240 POSTS
I would suggest starting there to check for a short. You'll need to remove the overhead panel.
Feb 1, 2010 at 11:51 PM
DAISYJ
Thank you. We remove the overhead panel and let you know.
Feb 2, 2010 at 1:19 AM
  • 110,240 POSTS
Let me know what you find. Electrical shorts can be a pain, so try to be patient.
Feb 2, 2010 at 2:28 PM
