1995 Ford Excursion timing
TURK58
1995 Ford Excursion 4 cyl Front Wheel Drive Automatic
at topdead at crank top dead at cam if i put the belt on will it fall back one notch
Feb 22, 2009 at 9:01 AM
  • 110,251 POSTS
It shouldn't. Once you have it on, double check it. If it does, remove it and try moving one or the other a slight amount to compensate for the belt.
Let me know if this helps.
Jun 20, 2009 at 3:23 PM
