Cranks does not start
120,000 MILES • 2.5L • 2WD • MANUAL
ARNELREYES
Crank but not starting.
Jun 11, 2018 at 8:02 PM
  • 110,248 POSTS
Hi and thanks for using 2CarPros.com
If it cranks but will not start, there are a few things which could cause it. The most common problems relate to fuel pressure and ignition spark. I am going to provide two links for you to follow. One will be checking fuel pump operation and the other ignition spark. Once you complete these tests, let me know what you find and then I can better direct you.
This one deals with ignition spark:
This one deals with the fuel system:
Once you complete these tests, let me know what you find or if you have other questions.
Jun 12, 2018 at 11:58 AM
