1996 Ford Escort Catalytic Converter
MIKE BROADWAY
hi.
escort cabriolet 1.8 zetec. 1996. Mileage = 92,000 miles.
How is is it possible to know when a catalytic converter needs changing, and what, if any, faults occur if the catalytic converter is faulty?
Many thanks
Mike B
Nov 16, 2006 at 7:25 AM
CATCH_15
  • 250 POSTS
I wouldn't replace it unless it goes bad. If it's no broke, don't fix it. Some symptomes of a bad cat. include decreased fuel mileage, sputtering, and the engine sometimes may die after a few minutes and act like it is starving for fuel. You may hear rattling in the exhause which means that the actual catylist has broken apart from the casiing.
Nov 16, 2006 at 8:58 AM
Suggested Repair
Do not replace the catalytic converter unless it has failed. Signs of failure include reduced fuel mileage, sputtering, the engine dying after a few minutes as if starved for fuel, and exhaust rattling if the catalyst has broken apart inside the casing.
Conversation Summary
The owner of a 1996 Ford Escort Cabriolet 1.8 with 92,000 miles asked how to tell when a catalytic converter needs replacement and what faults a bad converter causes. The expert advised leaving it alone unless it fails, and listed symptoms including poor fuel mileage, sputtering, stalling after a few minutes as if fuel-starved, and rattling from a broken catalyst substrate.
