Vibration in rear end of 98 Escort
JOEPSYCHO4
I have a 1998 ford escort sport with a manual transmition that has 150,000 miles on it. There is a vibration/loud noise coming from the rear end of the vehicle. It sounds almost like something rubbing but I can't seem to find evidence of anything rubbing. It gets louder as the speed increases and stops when I make a right hand turn. I can't seem to figure it out.
Thank you
Mar 4, 2007 at 11:46 AM
NOS
  • 320 POSTS
is your tire rubbing on the inner fenderwell? from maybe a bent wheel. and when you turn your shifting the weight of the car and it quites. 8) NOS
Mar 4, 2007 at 12:11 PM
JOEPSYCHO4
But the sound is coming from the rear and there are no signs of rubbing. I just had my tires rotated and had them check the suspention and for signs of rubbing and they found none. They told me that is may be an exhaust system problem of some sort. also if I have a heavy load in the back seat of trunk the sound is louder.
Thank you for your response
Mar 4, 2007 at 12:15 PM
NOS
  • 320 POSTS
has anyone checked out your exhaust system to see if a pipe is rubbing on the body somewhere. that is also possible and i can make one heck of a racket.
one other thought i had is it could possible be a bad wheel bearing and the more load you put on it the more noise it makes.
vote for me if you thing i have helped you at all any input is gratefull. 8) NOS
Mar 5, 2007 at 1:02 PM
98RANGERXLT
  • 301 POSTS
What exactly is it doing is not charging or is it overcharging i need to know because newer cars the voltage regulator is in the alternator
Jul 9, 2007 at 1:26 PM
