I noticed that the (L/H side) main headlight (as you are sitting in the car) is not working. I assumed it was the bulb but before purchasing i thought i would change the fuse. No change. I then decided to check all the lights and realised that when i put it on side light neither of them work, which is strange.
However both headlights work when on full beam (when the blue light comes on).
In short; Main beam L/H not working
Full Beam - both work
Side light - neither work!
I also have a problem with my dashboard lighting, as in it doesn't light up my speedo etc when i turn the lights on. I'm guessing this is all connected?
Basically i am asking what the problem could be for 2 reasons. Firstly i don't want to waste money by buying bulbs and fuses unnecesarily. Secondly if it does need to go to a garage it would be of great help to have some idea of the problem so that i don't get targeted with expensive or unnecessary repairs. Which i am afraid to say happens too much these days with women car owners.
I would therefore really appreciate you help and guidance.
Thank you :)
Anne
